Old 11-07-2005, 06:49 PM
nocturnal_demon_13's Avatar
nocturnal_demon_13 nocturnal_demon_13 is offline
Last Online: 12-04-2009 09:49 PM
nocturnal_demon_13 is on a distinguished road.
nocturnal_demon_13's Photo Albums My eBay
Originally Posted by Picasso
Just to clarify, you did test the rear brakes as outlined by Mustang67408 in his previous post?
I will try that tonight when I get off work. California Hwys are rarely empty or near empty....unless its at night. I get off work at midnight..I will try it then and make sure the rear drums are okay.
I'd give one of them a call just to make sure and see if they charge for it as well. Most brake shops should also be able to do it for you.
I went to a couple shops and they didn't have the tool/equipment to check the runout..sad to see that. I went to Midas and they would do it for $26.40. I went there, they jacked up the truck and then they told me their rotor runout indicater would break if we used it on my slotted rotors. He said if he was to use it and even if it didn't break that the reading would be incorrect because of the needle-like think would go up and down on the rotor surface when spun because of the slots. He said only a digital reader could be used and those were $3k and they didn't have one and they doubted any shop would have it locally. How am I supposed to check the run-out and makes sure its true? Can I get one that will work...how much $$ can I expect to shell out for one. Thanks for your quick replies Picasso I appreciate your help and time to respond.
2002 V6 SR5 AC: 2.5" Daystar kit w/TRD Red/Blue shocks | 1" Rear Block | Bilstein 5100's Rear | 265/75/R16 BFG TA KO's | American Eagle 102 Wheels 16x8 | Clear Corners | Chocolate Brown Sparkle Paint Job | Sylvania Silverstar ST 9003's | Sylvania Signals 3157A's ST| 13.1" Overhead DVD-LCD | 14856 Magnaflow |
2006 V8 SR5 DC: Bilstein 5100's Adjustables @ 2.5" |Debadged | 5% Limo Tint Back 3 Windows & Top Windshield | 20% Front 2 | Color Matched Mirror Covers - Front Bumper Strip & Rear Bumper| XSP Black Grille w/ Custom Charger Emblem | 14586 Magnaflow | 5100's Rear | LED Tailights| Tinted Tailights & Headlights @ 17%| 33x12.5x18" Toyo MT's & AR THUG 18x9 Wheels |
