Thread: Safety Recall!
  #266 (permalink)
Old 11-08-2005, 10:59 AM
anmrivera's Avatar
anmrivera anmrivera is offline
Last Online: 09-01-2009 08:41 AM
anmrivera is on a distinguished road.
anmrivera's Photo Albums
Originally Posted by bunker7
Hi.
Just had my 03 Tundra serviced and they did the recall on the LBJ's at the local dealer. Am I mistaken in assuming that a alignment has to be done after the lower ball joints are replaced? The service department says they can change the balljoints with no effect on the alignment. Is this correct?
A have just put a new set of tires on and don't what to see them wear out early.
Hans
I read somewhere on here that if the tie rod ends were removed an alignment should be performed. I crawled under my truck the day before I had it done and marked the cotter pin to the tie rod bolts with a black permanent marker. I also did not see a way to remove the LBJ with out disconnecting hte tie rod anyway. Long story short, they obviously removed the tie rod cotter pins and my dealer ended up aligning my truck too. It pulled to the right a bit before the job and now the steering wheel is straigh when the truck is driving straight. I would tell them to do it. It is part of the job I think.
2003 Tundra 4x4 Access cab V-8, SR5, Silver Sky Metallic, TRD Off-Road package, Tow package, LSD, cold weather prep. package, Running boards, Convienence Package, Line-X bedliner, debadged, 4 window visors, Blue Cyber Eyes, $5 rs3200 upgrade , Fog light mod.
2005 Sienna LE 8 PAX, White, Full Curtain airbags, Tow prep package, VSC, Rear Disk brakes, rear audio, aftermarket entertainment center(will be bought soon)
I'm a proud Toyota Bigot!!!
Midwesterners checkout the midwest forum!Click here
