fuse tap
If you haven't been able to get this to work yet, I suggest just buying a run of the mill male crimp on spade connector. (I think i'm describing it correctly). I think it was a little wide for the Taco fuse socket, so i just cut it down to the right width with a pair of wire cutters. I connected it to an unused fuse socket that was switched off the ignition. There was a fuse inline on the device I was wiring in and it worked fine. Good luck.
Duncan
