Old 11-27-2005, 10:58 AM
captain.bob captain.bob is offline
captain.bob's Photo Albums
Last Online: 11-20-2006 06:34 PM
captain.bob is on a distinguished road.
Originally Posted by mikeg281
Curious, if the mini fits fine why replace it? Just because it's sticking up a little higher? I mean the box is covered and the hood is shut.
Mike
I AGREE !
The issue was....I needed a replacement fuse and was also looking for a "fuse tap"....I took the Toyota (I'll call it a micro-blade) Fuse to 5 different auto supply stores and nobody new what it was or could offer a solution, except "you will have to get your replacements from Toyota" !
Solution is the standard "mini-blade fuses" do seem to fit the fuse block. BUT to make certain everyone is clear they do "stick-up" higher than the micro-blade fuses. NO PROBLEMS that I can see in either the engine compartment MAIN FUSE box or the small fuse panel in the cab on the drivers side (this is where I wanted to make my "tap" off the accessoriy fuse).
SIMPLE ANSWER TO YOUR QUESTION....for now I don't see any problem with using mini-blade fuses and the fuse taps are readily available for mini's.
If I did this correctly you should see some attachements of the fuses and taps.
Captain Bob
http://mysite.verizon.net/captainbob7/tuna.htm
2005 Silver Tacoma 4x4 Doublecab w/ TRD Off-Road Pkg
SS Tube Steps, Access Cover Tornneau, Loadingzone bed divider, Beeping turn-signal mod, wireless backup camera
