Leveling Tundra
I found that if just leveling your Tundra is what you're after then the least complicated and economical way is to lower the rear.
I used Bel Techs shackle replacement kit #6400 and got a true 1 3/4" rear drop. By my measurement with stock wheels and tires the rear is still a 1/2" higher than the front but it's hardly noticeable unless I had not pointed it out. This mod has the added benefit of not adversely affecting the trucks handling or tire clearance. You will have to reaim your headlights but other than that, that's it.
