Vehicle speed signal system
The vehicle speed is detected by the ABS speed sensor and the signal is input to TERMINAL SPD of the engine control
module via the comb. meter and the skid control ECU with actuator. (A/T)
Meaning, it uses all the wheel speed sensor to determine vehicle speed. You will have to tie into the signal right at the vehicle combination meter
25 yrs with TOYOTA
RENTAL VEHICLES
