Dave,
Hopefully it's not a leaky head gasket that partially fills one cylinder with antifreeze. I had a turbo 4cyl that did that every 80k miles, letting me know it needed a head gasket. But it had a aluminum head on a cast iron block. A sealer pill added to the radiator would prolong the replacement procedure. Pulling the spark plugs when it was rapping showed AF on one of the plugs.
Doug
'01 tundra TRD SR5 4x4 access cab, rear Helwig sway bar, front poly end-links, temp/compass mirror, '05 tail lights, JL audio stealthbox and amp, 6x9 Sony rear spkrs, TO-25 door tweeters, new '03 TRD coilovers w/daytech 3/4" poly spacer, rear HD-Bilsteins, all weather mats, rear seat mod, Draw-Tite bugshield. Soon to install: TRD lim-slip
My photos
