Old 01-11-2006, 01:04 AM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: '03 Supercharger problem
Originally Posted by wardamneagle
I recently purchased a 2003 LC with a supercharger (engine upgrade?). It had one previous owner. 3 months ago, the engine had to be replaced - the LC broke down on the interstate. My local dealer replaced the engine and then a test drive blew that engine up, and that was when they realized the problem was in the supercharger. They removed the supercharger and sent it to CA, and after 6 weeks we haven't heard anything about it from the people working on it.
Does anyone here have a supercharger? Since my local dealer doesn't seem to be familiar with them, I have basically no knowledge about it. Are they difficult to maintain? Any help or directions to information would be greatly appreciated!
S/C's are pretty self sufficient. Your dealer should have had the S/C checked when the first engine blew up. You'd be surprised about the amount of shrapnel that goes thru the engine when they blow. This usually contaminates the S/C and it should be sent out to be cleaned or repaired.
The only thing to do to them is check the belt and if you know how, check the oil level. I have only ever serviced 1.
How did the engine blow on the test drive? caused by the S/C? curious about this. What did they tell you?
Anything else you have a question about S/C?
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
