Originally Posted by Herbicidal
Hi everyone! I'm posting on behalf of my coworker. He owns a 2002 Prius. He is burning through tires in less than 30,000 miles per set. He was told by the dealer that he can only use one of two different brands of replacement tires - Bridgestone or Dunlops that have specific values for low rolling resistance. If he uses anything else, his entire vehicle warranty is void!!!  Can this be true?  This may be specific to that model year, I'm not sure on that point. He is currently using Dunlop RE910's.
Thats about the biggest buch of BS!!!~!!! I have ever heard.
Going thru tires at less than 30k miles is normal on a prius. I would caution him in using anything other than the recommended tires, reason = the fuel mileage will drop. Other than that as long as he stays with the same size tire and doesnt go any wider or taller it WILL NOT VOID THE WARRANTY,
unless it can be proven that the tires caused the problem and thats not likely to happen.
A bigger or smaller tire will throw the computer off, and it will affect mileage and acceleration. It was designed for the low resistance tires.
It is illegal for them to tell you that
Click here-->
http://www.ftc.gov/bcp/conline/pubs/...s/warranty.htm
Hope this helps
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
