Old 01-20-2006, 10:15 AM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408 has blessed us with their presence. mustang67408 has blessed us with their presence. mustang67408 has blessed us with their presence.
Default Re: 2002 Prius replacement tires.
Originally Posted by Herbicidal
My friends Prius has just about 80,000 miles on it. Are there any potential problems at this point switching to synthetic's?
What we were told was, Toyota seals were not designed for synthetic. The synthetic molecule is smaller and has rounded egdes, this will allow it to more easily slip past the seals. The springs in the seals are designed with "x" amount of tension to keep conventional oils in. Some people swear by it and have no problems. I had a bad experience with synthetic oil so between that and the cost, I wont use it. Dont believe in it. I change oil every 2500 miles and will do that till the day I die. Never had a engine problem in any vehicle I have owned and maintained.
It probably wont hurt anything, But the only way to tell is for him to just try it.
I know my luck and wont make that mistake again.
PRIUS's ROCK!!!
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
