Old 01-23-2006, 09:26 AM
theyotaguy theyotaguy is offline
Last Online: 10-09-2009 10:40 AM
theyotaguy is on a distinguished road.
theyotaguy's Photo Albums
Default Re: 2002 Prius replacement tires.
The reason the Prius tire is unique is because it is has a higher load rating.Read the sidewall of the OEM tires for the maximum load,and make sure that the tires that are installed have at least that same rating.The Bridgestone tires that are OEM are clearly labeled "Extra load",because they also make the same size and model tire that is a standard load tire.
*A parts man with a code-reader is NOT your friend!
*The most expensive parts are the cheap ones that let you down.
*Testing ROCKS - parts swapping is for the .
*Anybody can take a dump in a box and mark it guarranteed,but what you really need to do is buy a quality part.... "Tommy Boy"
