Re: Alignment problem
there are a lot of posts regarding alignment issues. if it's purely an alignment problem, then it boils down to this:
- make sure the shop is using hunter equipment and knows how to use the CAMM adjustment feature
- use DJ's specs and take them to the shop (post the before and after here and that you have now and let the members take a look)
- don't let them get away with charging you for extra alignments if they havn't done it right the first time
but, since you mentioned them putting a new rack and pinion in, that may also be suspect so i would post the alignment info first to see what dj or others have to say.
you also put on new tires and rims so there's potentially a problem with one of the tires. sometimes a bad tire (usually a belt inside) will cause strange behavior.
toyota tundras that are propertly aligned do not have a problem pulling to either side.
