Re: Oil Filter Change
This is not unusual. The washer has most likely extruded into the threaded portion of the drain bolt. For your next change, I have found that I can take a knife and slide it in between the washer and the pan and pry it off. Don't use so much force that you damage any sealing surfaces. Welcome to the forum.
