Old 02-07-2006, 04:33 AM
SuperBusa's Avatar
SuperBusa SuperBusa is offline
Last Online: 11-21-2009 03:33 AM
SuperBusa is on a distinguished road.
SuperBusa's Photo Albums
Default Re: Oil Filter Change
Originally Posted by josemarie
... when I took the drain bolt off, when I tried to remove the washer, it would not come off. It does not look like the one they give/sell you with the Toyota oil filter, it's smaller, not metal.
I'm sure the Tundra uses the same drain plug washer from the factory as the Tacoma ... which is an aluminum washer with a thin layer of black rubber on both sides to help it seal. It's the black rubber that's making it stick to the pan. I just worked it carefully with a thumb nail and it finally popped off.
You can use the orginal style washer or the fiber one from the dealers ... I haven't had problem with either one. Used the fiber style on my old Toyota truck (V6) for 13 years with no problems ... just change it out with every or every other oil change.
