Can't grease prop shaft on 4X4
Does anyone else have issues getting their grease gun in the u-joints of the prop shaft for the 4wd? I've tried spinning the shaft in every way possible and still no luck. The diameter of the gun's tip is a bit too large to fit between the knuckes of the u-joint. I have two grease guns and both have the same diameter tips. Luckily, I rarely use 4wd so it isn't a huge issue, but I would like to get some fresh grease in there due to the salt and other **** we have up in MN. Is there a narrow tip you can put on a grease gun? I've pumped litterally hundreds of gallons of grease in my day (farm boy) and never have had this much of an issue before.
