Old 02-28-2006, 05:00 PM
v8Toilet's Avatar
v8Toilet v8Toilet is offline
Last Online: 08-20-2009 06:58 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
Default Re: custom y-pipe or stock y-pipe?
The stock y-pipe looks restrictive but is actually a good merge collector. A supercharged Tundra with a stock y-pipe put down 300 rwhp on the same dynamometer where I put down 220 on the same day.
I’ve also changed mine for the SS-autochrome clone of the JBA y-pipe and didn’t notice any difference except more noise. It was leak prone so I went back to stock.
I say you should not mess with it because I believe it’s an engineered part made to support low and mid range torque. The kind of low and mid range torque a heavy truck like yours needs to get it moving.
From all my experience of trying different exhaust systems and headers, doing dynamometer runs, testing at the track, the only exhaust parts worth improving for more power on a naturally aspired V8 Tundra are the muffler (not the exhaust pipe) and the manifolds. Don’t change out the whole exhaust with a cat back 2-1/2” system but just change the muffler and keep the stock 2-3/8” exhaust pipe if you want the best most improved low and mid range torque.
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
