Old 03-01-2006, 01:46 AM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408 has blessed us with their presence. mustang67408 has blessed us with their presence. mustang67408 has blessed us with their presence.
Default Re: Power lock problem 1996 Camry LE sedan
Originally Posted by bobawoz
Hello, would appreciate some ideas on what might be causing the driver's side power locking switches (both the key cylinder switch and the inside push button switch) to not work (not even a sound can be heard, circuit is not energized at all). At the same time, the driver side power unlocking switches (both key cylinder and inside push button) work normally. The passenger side power locking and unlocking switches (key cylinder and inside push-button) work fine. Since the passenger side locking switch locks all four doors, I figure that my actuators are all good? I replaced the push button lock/unlock switch on the driver's side but still have problem. Don't know if this is related to the locking problem but my power side mirror adjustment control does not work for the driver's side mirror but does work for the passenger side mirror. Am I dealing with some sort of wiring problem? Where should I be looking?
Thanks mucho!
Let me check my notes tomorrow and i will try to get back to you ASAP.
It sounds like the micro switch built into the drivers door latch (inside the door).
Anything aftermarket added? alarm? stereo? battery changed recently?just curious.
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
