Re: Power lock problem 1996 Camry LE sedan
Here is a PDF that will help you test the inner workings of the door lock system. There is a unlock switch on the back of the drivers cylinder and key and a micro switch in the latch mechanism. You may or may not have the switch on the key portion, due to the fact you dont have the factory alarm.
Use the PDF's as a guide.
Since it wont unlock or lock with the key, that tells me there is something wrong with the latch mechanism, and that would be the first place to start.
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
