Originally Posted by bobawoz
mustang, before I start to disassemble driver's door I would like to check the door lock relay first. When I inspected behind kick panel and under hood I could not find this relay...is it in the door?
Thanks
The door lock relay is in the passenger side kick panel (D8), see attachment.
Make sure the clips on the door key cylinder are ok when you get the door panel off. Make sure all linkages are functioning properly and that the small spring inside the latch mechanism is intact.
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
