03-04-2006, 03:03 AM
KE7WLF Master of Disaster
Re: Power lock problem 1996 Camry LE sedan
Originally Posted by bobawoz
Thanks mustang, using the pdf files you posted I tested latch microswitch and actuator. The microswitch tested good but the motor/actuator turned out to be defective. I will be installing new latch mechanism as soon as I can get the part.
 YW
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
