Re: code p1135
Bank 1 is the bank closest to the firewall . Bank 1 denotes the bank with cylinder #1 in it. Sensor 1 is the first sensor in front of the CAT.
Attached is a document that may help you see which is which.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
