Thread: Rav 4 Oil Pump
Old 03-27-2006, 12:54 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: Rav 4 Oil Pump
Has the Rav been well maintained?
If it has you might have a Oil sending unit problem. A oil pressure test will determine if the oil pressure is ok.
If it has not been maintained well, then I would suggest just removing the oil pan to see if there is any SLUDGE build up, clean the pan and replace the oil pump pic up tube, then check the oil pressure.
25 yrs with TOYOTA
