Old 03-27-2006, 06:56 PM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: Check Engine light on; then a problem!
Here ya go with a how to replace straight from toyota.
After you replace it make sure to disconnect the battery to clear the code and reset the ECU.
You may need a SCAN TOOl to set the % of throttle opening.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
