Re: Rear suspension noise
Your supposed to remove the rear seat (see attachment) to gain access to the rear struts.
I would lubing them and if that doesnt work replace the upper strut supports if the struts show NO signs of leakage.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
