Old 04-21-2006, 11:09 AM
cupidstoy's Avatar
cupidstoy cupidstoy is offline
Last Online: 12-31-2008 07:02 PM
cupidstoy is on a distinguished road.
cupidstoy's Photo Albums
Default Re: Stripped spark plug thread
safest way is to remove the head and drill it out. it's more work but not more work then rebuilding the engine if a little piece of metal gets into the cylinder and starts grooving out the wall so it burns oil or worse, causes a hot spot and the piston or rod shatters and goes through the block.
another consideration is why did you "blow" a spark plug in the first place and why did it strip the threads? if the plug was loose, the threads could have "burnt" but the car would have been running pretty badly up till that point. if the mechanic overtightened the plugs last time they were out, that could have stripped the threads and caused the loose plug and then the repairs should be on that person. i realize that may be your husband or may be hard to proove.
anyway, just noting that something else is going on here and the root cause should be found and fixed if the car is worth keeping at this point.
good luck!
2004 Tundra DC Limited Phantom Perl Gray w/ Oak Leather Interior (power sunroof, Kazuma TRD LSD, Advance 4 panel hard tonneau cover, Hellwig antisway bar, lighted running boards, dual battery setup with 1500 watt 120 volt power inverter, additional 'always-on' 12 volt outlets, aftermarket dual zone heated seat kits, Blizzack W965 LT235/85R16 winter tires on stock steel rims, JBA cat-forward titanium ceramic coated headers, tinted front driver's and passenger's windows, alignment to DJ's specs, Roadmaster VR-3 backup camera, Waeco 12 volt fridge/freezer, and, the best for last.... black rubber floor mats from Sams.) Recently added: baby seat!
Wish list: too long, wife would kill me!
2003 Corolla (bone stock, but well loved and cared for!)
"Expect the impossible."
- JC and the Brothers of Thunder
