Originally Posted by liveBLUE
Do you have any idea how can I access to the DRL? Do I have to take out the whole middle part to get to it?YES cause I took out the top last night and couldn't see it. maybe it's quite low. I hope someone will give me some directions. thanks!
You have to take the entire upper and lower dash out to get to it.
They dont make these vehicle easy to work on anymore.
Good luck
25 yrs with TOYOTA
