I use a product called Wheel Mate which is 0.030 of an inch and goes between the hub and the wheel. Put one on each wheel and the wheels comes off with just a tap, problem solved. Got mine from AutoBarn.
Originally Posted by mikemock
I recently replace my tires had observed in interesting phenomenon that distrubs me. The guys replaceing the my tires removed all the lug nuts and had a a very hard time removing the wheel. The wheel seem to be bonded to the axel. The had to use a mallet to get it off. They had explaind that they had a different car that took them several hours to remove the wheel.
I am concerned that one day I will get a flat tire and won't be able to remove the wheel. I think this can even be dangerous if I get a flat in the rain or in winter when the ground may be slippery, or if I cant find perfectly level ground to jack up my truck.
Has anyone else had this problem, and what is the best way to prevent it.
Can the tire be lubricated, and with what kind of lubricant?
