Originally Posted by ServoScanMan
Hey Mustang,
I just noticed you are from Henderson. We lived near Pecos and Windmill. We moved from Henderson,NV to Lorena,TX in 2002. Our Discovery motorhome came from Findlay RV. I may have an old friend you know in Henderson. His name is Chris Lamb and he is a Matco Tool Rep. Anyway, just want to say 'Hello'.
Hello hope all is well with you.
I live near Colledge and Mission (on the way to Boulder City)
Yes, I do know Chris Lamb
Your terminology is ok with me, I just wanted to be sure we were talking about the same thing
If the engine is running then it should show on the screen. It should show it either powering the axles, chargiung the battery or any combination there of and more.
The 2004 and a few 2005's had a problem with the NAV unit. We replace them with exchange units and problem is usually cured. Its an internal NAV Problem and has to be swapped out. I would see the dealer. Sometimes the NAV malfunction will also cause the A/C not to work properly.
The "ICE" wont run unless it is doing something and the screen should show what it is doing.
Hope this helps.
I will look next week and pay specific attention to this on a 06 that I have coming in for a service.
25 yrs with TOYOTA
