Old 05-01-2006, 10:26 PM
Siriusarcher Siriusarcher is offline
Last Online: 03-16-2008 03:31 PM
Siriusarcher is on a distinguished road.
Siriusarcher's Photo Albums
Default 2000 echo check engine light
Howdy
My first post here...
Thought I'd share what I've learned recently about the fuel delivery system in this car: Had the check engine light, with poor idling, poor acceleration (bogging when I hit accelerator), and occasional stalling at idle, which is a huge safety issue given the vacuum assist brakes and power steering.
Brought to my mechanic who found the p0172 (rich on fuel mixture). He diagnosed a failed O2 sensor, which was replaced, to no effect. After that, he recommended a new throttle body assembly thinking that the idle motor or throttle position sensor was pooched. These can't be fixed--gotta replace the whole TBA. I went to dealership, bought and installed the part, reset EFI, all to no effect. Finally, on a whim, I pulled the mass air flow sensor out (small philips screwdriver needed), cleaned it with a thimbleful of rubbing alcohol, a q-tip and shot of compressed air. Re-installed and reset compter (pulled EFI fuse B). Voila! problem solved! No bogging, better mileage, no stalling. Could have saved about $700 if I had tried that earlier. Consequently, I've got a perfectly good throttle body assembly sitting on my work bench. Anyone with similar experience?
