Old 05-02-2006, 03:03 PM
PineRidge PineRidge is offline
Last Online: 05-02-2006 03:47 PM
PineRidge is on a distinguished road.
PineRidge's Photo Albums
Default Re: Heater quit... sort of
Originally Posted by wizzer
My 2001 Highlander heat just became quite intermittent. I have the manual temperature control version with the 3 knobs, not the automatic climate control. There is just one little place on the dial where the heat comes on full blast. It seems to move around and the heat will work for a while then stop. Then I adjust the knob around and find the hot spot and the heat works fine for a while. Except that it is full on. The fan works fine and the control for where the heat is directed also seems fine.
Anyone with experience with this? Is there a part I can replace? Does the dash panel around the heater radio, etc remove easily? And if so how? Anyone know of a reasonably priced source for any parts that I might need?
Thanks
Your problem is most likely one of the servo motors located just behind and to the left of the glove box or the main control with the 3 knobs. I puleed the glove bow in less than 5 minutes.
In my case it was the latter and I contacted a auto recycler to acquire a used part. Toyota wants $650.00 for the dash control. BTW get your fingernails or a small screwdriver under the trim as it pops off, without screws.
