  #16 (permalink)
Old 05-02-2006, 03:21 PM
PineRidge PineRidge is offline
Last Online: 05-02-2006 03:47 PM
PineRidge is on a distinguished road.
PineRidge's Photo Albums
Default Re: Sun Visor Problem
Originally Posted by milesprower
The part I referred to as the bracket is the metal shaft (that sticks into the visor) and the flange with (three screws, I think) that secures the visor to the ceiling. You have to ease the shaft out of the visor. It feels like it won't go, but if you are patient and use enough steady force, it will eventually start to come out.
Mine's a 2002 Highlander with the same problem. My initial fix was to put a small dot of RTV to hold a small square of velcro to the headliner. This works well but now I think that I'll just try your cure as it sounds a lot more professional than my jerry-rig solution.
Does anyone know if the Highlander visor is interchangeable with any other Toyota models? I would gladly give up the HomeLink for a visor without, that works like it should without paying the $600.00 that Toyota wants for a replacement.
