Re: Changing the antenna - better or worse?
I changed to a 9" black "stubby" antenna. No change in reception. Looks GREAT.
Total time to install - 30 seconds. It is not square on the bottom like the stock antenna but round, so do not use any tools to tighten the antenna as you WILL scratch it. Hand tighten and only if you think it will vibrate loose (I just did mine hand tight) use some Locktite to be sure it stays in position.
Hope this helps.
