Re: Too much swaying?
98Hawk,
I have a 2000 Limited Tundra. First order of business would be to make sure your tires are filled up to the maximum limit (all 4) this helped my truck right off the bat. Then I would add a Helwig Sway bar to keep it from leaning too much in the corners. So now we have spent about $150 or so and you should see definate improvement. Trailer loading as another pointed out is also important. Our trucks come with Load Range C tires. These are very comfy and cushy to ride on. You can put Load Range D or E on your truck and inflate them and this will change the ride to be much firmer.
Hope this helps.
Ken
JBA Headers, Gibson Muffler, Daystar Front Level Lift, CDT Kama Speakers, Elemental Designs 9.4 Amp, Eclipse CD2000 Head Unit.
