  #43 (permalink)
Old 05-30-2006, 09:34 PM
cowboy bebop cowboy bebop is offline
Last Online: 11-17-2009 06:12 PM
cowboy bebop is on a distinguished road.
Send a message via AIM to cowboy bebop cowboy bebop's Photo Albums
Default Re: FIRST PICS!! New Tundra intake manifold, dual plenum
A standalone is not required when a stock TB is used. If the IAC is retained, and the stock TB used, then I'm not sure why a standalone would be needed. We are currently working with Rob Welsh, however to bring a 100% plug n' play harness to market that adapts an Supra MKIV TT AEM EMS to the 2uz-fe. It is in process this week, and testing will begin soon.
It should be said that this manifold is not for everyone. If you are on a budget, then there are other ways to make gains besides this manifold. It should be said that this manifold is a gateway to more HP, and not so much a direct cause of it. Most folks, sadly, don't understand what that means. This manifold will only give you, what you put into it. No one can expect massive HP gains with it alone when the rest of the motor is stock. Add a supercharger, cams, and headers, and things will be different.
The differences between the stock manifold and our manifold are apparent. Porting the stock manifold efectively would be a hell of an undertaking and still would solve the root problem, that being the 15 inches of runners. Our runners are only 3.5inches in length, and a plenum volume of approximately 6 liters, so it would stand to reason that our manifold flows tons more.
Eric
