Old 06-01-2006, 12:31 AM
vilnis vilnis is offline
Last Online: 06-01-2006 02:14 AM
vilnis is on a distinguished road.
vilnis's Photo Albums
Default Re: After market sunroof?
No problem to install Hollandia 730 or the 500 (Grandview)
Just had the Grandview installed in Vancouver BC. Even though it is rather long, no cross beam was encountered. The one cross beam is located far back (in line with the back of the rear seat window). The trick (I was told) is that the frame of the sunroof should not be on top of a roof ridge but rather be at the bottom of the roof. If you check your FJ roof you'll see that this will translate into something of a max width (cut out) of appr. 31.5". That will give you either the Hollandia 730 or the 500. Both by Webasto. The 500 is however NOISY! The 730?
