Old 06-03-2006, 08:56 AM
cupidstoy's Avatar
cupidstoy cupidstoy is offline
cupidstoy's Photo Albums
Last Online: 11-14-2008 02:13 PM
cupidstoy is on a distinguished road.
Default Re: I want a smooth riding Tundra
i think tire pressure may contribute most to the smoothness and bump absorbing quality of the ride. if your tire sidewall is stiff enough, try airing down in 5 psi increments front separate from back to see if you can get the balance you are looking for. be careful, of course, that you don't go too low where a tire can roll off the rim (usually you are safe to go down to 1/2 the max pressure posted on the sidewall or possibly lower). your gas mpg and cornering will suffer a bit, but the ride will definitely be much more forgiving on the straight highway stuff - especially in the fronts where you feel it the most.
i know it sounds contradictory, but i actually get a smooter ride from shorter sidewall tires with good build quality and running lower psi. you'll have to invest in a tire specifically sized for this goal next time you purchase new rubber. you can't air down a regular 65 series tire without getting a lot of roll in corners. but moving to 55 or 50 series with a good sidewal and possibly inching up your rim size plus running lower pressure gives a nice combination of forgiveness on bumps plus decent handling on corners.
2004 Tundra DC Limited Phantom Perl Gray w/ Oak Leather Interior (power sunroof, Kazuma TRD LSD, Advance 4 panel hard tonneau cover, Hellwig antisway bar, lighted running boards, dual battery setup with 1500 watt 120 volt power inverter, additional 'always-on' 12 volt outlets, aftermarket dual zone heated seat kits, Blizzack W965 LT235/85R16 winter tires on stock steel rims, JBA cat-forward titanium ceramic coated headers, tinted front driver's and passenger's windows, alignment to DJ's specs, Roadmaster VR-3 backup camera, Waeco 12 volt fridge/freezer, and, the best for last.... black rubber floor mats from Sams.)
Wish list: too long, wife would kill me!
1993 Nissan 240SX SE Coupe Burgandy w/ Gray/Black Interior (Eibach Sport lowering springs, GAB adjustable struts, custom fabbed front strut bar, powerstop cross-drilled rotors, Axxis metal master pads, stainless brake lines, American Eagle alloy 17" rims, P215/45R17 tires, short throw shifter, borla stainless cat back, K&N filter w/ ram air feed and insulated intake pipe, Flex-a-lite twin thermostatically controlled cooling fans; Optima redtop battery, powered sub, sony amp w/ Pioneer/Alpine speakers and factory HU, sunroof, heads-up display speedo)
2003 Corolla (bone stock, but well loved and cared for!)
"Expect the impossible."
- JC and the Brothers of Thunder
