Old 06-05-2006, 08:10 PM
mustang67408's Avatar
mustang67408 mustang67408 is online now
KE7WLF Master of Disaster
mustang67408's Photo Albums
Last Online: Today 10:09 AM
mustang67408 will become famous soon enough.mustang67408 will become famous soon enough.
Default Re: Rear suspension noise
The bolts are 12mm.
There is NO tension on the sway bar, just be careful when removing the bolts,so that the sway bar doesnt fall and hit you in the head
The bushings are cut and slide right over the bar and are NOT threaded on.
I would recommend a silicon grease lube applied to them before installation.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
