Re: 2006 Toyota Prius - Navigation System
The 04's and 05's had an issue with the NAV system going wacko and doing some very weird things. It is possible that the HEAD UNIT (IN DASH) has an internal malfunction. Your 06 should still be under warranty. I would recommend taking it to the dealer and let them pull some diagnostics on it and see what they find.
25 yrs with TOYOTA
