Old 06-11-2006, 10:20 PM
Eddie's Avatar
Eddie Eddie is offline
Moderator
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
Default Re: Lexus RX 300 2000
Originally Posted by parrott
Thanks. I will get one tomorrow and change it out. My car also will not idle some time. Under 1000 rpms it just shuts off. I can keep it over 1000 and drive but when I let off the gas it shuts right off. After I drive it down the road a ways it will run fine. After I replace the sensor do I go back to Autozone to have anothe scan done?
Sounds like the idle air control motor is going bad. You won't get codes with a bad IAC though. After replacing the AF sensor see if the idling problem still happens...I don't want someone replacing more parts unless it's necessary.
