Old 06-12-2006, 09:59 AM
paulfweeks's Avatar
paulfweeks paulfweeks is offline
Last Online: 10-30-2006 09:42 AM
paulfweeks may have some regrets.
paulfweeks's Photo Albums
Default Re: Hack for Eclipse Avn 30 w/out pressing brake
My AVN 30 was dealer installed in my 2005 Toyota Camry as a present(six months after car was bought) . The installer apparently knew set it up so that it always looks like the brake is on to the GPS system. I don't know the detail but I suspect it is just a case of "grounding" or "connecting" the control lead to a positive source. Unfortunately I don't think I have the installation manual. Will check and if I find it will re-post with whatever info I find.
System works absolutely great. You can even use it to check your speedometer setting/accuracy [and re-calibrate it to compensate for tire wear].
Paul F. Weeks
