Originally Posted by haroldo
Hi there,
I am not comfortable 'messing around' under the dash board.
The heat knob (shows the line pointing to the temperature) and the surrounding temperature numbers fail to illuminate...most of the time.
For some reason, every now and then they illuminate (for a few minutes). Since dead bulbs and blown fuses (usually) don't come back to life and then die again only to come back again, I'm going to guess that the bulbs and fuses aren't blown (although I am not an expert).
The lights have illuminated two or three times in the last year.
Any clue on what could cause this behaviour?
First thing I would do is replace the bulbs. he vibrations will make them come to life now and then. (its also the cheapest thing to start).
The next thing I would check is the wiring to the bulbs while you in there replacing the bulbs.
25 yrs with TOYOTA
