Originally Posted by haroldo
I'm pretty good at changing bulbs in the den and living room, but never did it in the dashboard, is there an easy way to do it...for the novice. Any online explanations? Thanks!
Here is a pdf on how to take the dash out.
Only USE STEPS 1 -23
There are 2 bulbs for that heater knob control. (bulb # 90069-98004)
Hope this helps.
25 yrs with TOYOTA
