Old 06-13-2006, 03:16 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: 96 Camry heat/fan control knobs lights
DO NOT REMOVE STEERING WHEEL (SKIP STEP 6) the dash will come out, just hold your tounge properly.
Some of the other steps may be unnecessary as well, use your judgement. If it says remove something on the passenger side and you see it does not interfere with the piece your after then skip that step. If in doubt then remove it, beats breaking things.
This is the only documentation I could find showing the heater control removal. It is really for the dash removal.
A phyllips screw driver, 8mm and/or 10mm socket and wratchet w/extension.
25 yrs with TOYOTA
