Old 06-13-2006, 03:28 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: 96 Camry heat/fan control knobs lights
This should get you in the ball park.
7. REMOVE STEERING COLUMN COVERS
10. REMOVE COIN BOX
(a) Press on the sides of the box while pulling the box outward.
(b) Remove the box.
11. REMOVE INSTRUMENT PANEL LOWER PAD
(a) Remove the 2 screws and the coin box bazel.
(b) Remove the 4 bolts, screw and lower pad.
18. REMOVE CENTER CLUSTER FINISH PANEL
Using a screwdriver, remove the panel then disconnect the connectors.
HINT:
Tape the screwdriver tip before use.
19. REMOVE CLUSTER FINISH PANEL
HINT:
Tape a screwdriver tip before use.
(a) Remove the 4 screws.
23. REMOVE HEATER CONTROL
(a) Pull of the heater control knobs.
(b) Remove the 5 screws and hang the heater control.
(c) Disconnect the air mix damper control cable.
(d) Remove the heater control.
25 yrs with TOYOTA
