Old 06-13-2006, 10:28 PM
ctrj ctrj is offline
Last Online: 10-20-2009 01:24 AM
ctrj is on a distinguished road.
ctrj's Photo Albums
Default Re: Replacing Lost Master Keys
Originally Posted by databasecar
I've read recently that if you lose both master keys, you need to have an extensive replacement of the computer components, resulting in a very expensive repair. Is it possible that the codes and other information to make a new master key would be available in the dealer's or Toyota's database ? That is, would this have been programmed in at the factory (or delaer) and could this information be retrieved by knowing the VIN ? Similarly, could one use the valet key as a starting point for accessing such a database, if it exists ? Isn't the code in a key the same unique one as in the master ?
Yes, your new keys have to be programmed at a Lexus Dealership. Depending on the year and model you have, the computer will have to be replaced in order to have the news keys programmed. If that's the case, contact your local dealership, as Lexus should cover the cost of the new computer if its the first time this has needed to be done. You are required to order 2 new master keys and pay for the labor to install the new computer, usually an hour. If you happen to have one of the newer models, you only need to order new keys.
If you have further questions, you can call me and I can try to explain it better for you.
Ryan
Ryan
2007 Toyota Yaris Base Sedan 5 speed, 51k miles
1997 Toyota 4Runner SR5 V6, 5 speed, Old Man Emu 881 front coils w/ N91 shocks, Old Man Emu 891 rear coils w/ Old Man Emu N86 shocks, 285/75/R16 Nitto Terra Grappler AT's, 1998 Toyota Land Cruiser wheels, LockRite locker in rear axle, TJM-17 front bumper, Deckplate mod, K&N air filter, Alpine CDA-9883, Scan Gauge 2, Cobra WX75ST cb radio, Yaesu FT-7800 ham radio, 168k miles
