Originally Posted by Rav4Rox
I need page 26-42.
Thanks in advance!
btw, i was told that after market fog lamps even when installed using the factory pre-wire will not show on the dashboard eventhough there is one fog lamps sign. is this true?
Hope these help, they are for a 2006 RAV
p.s. If you subscribe, you'd have access to all this and more
If your using the factory wiring it should work. As long as the body ECU sees the proper signal it will send the signal to the combination meter to illuminate the fog light indicator. Your probably going to need the factory headlight/foglight switch. It sends a signal to the body ecu, which in turns send a signal to the combination meter.
25 yrs with TOYOTA
