Originally Posted by rami
Just replaced my tires on my 2004 Prius at ~ 40,000 miles in February with 4 new BF Goodrich tires (P185/65R15 86T). Noticed a significant drop in mpg (more than 5 mpg) which I could not understand. After reading this post & the responses it sounds as if the reason for the decrease in mpg is because of the tires. There was no warning or indication in my owner's manual about using a specific tire, where did you find that information? What tires are correct?
Thanks
The "TIRE SPECIFICN WARNING" is only for the FIRST GENERATION (2001-2003) Prius.
It has nothing to do with your 2004.
25 yrs with TOYOTA
