Old 07-01-2006, 04:22 PM
Johnnny Rock's Avatar
Johnnny Rock Johnnny Rock is offline
Last Online: 09-22-2009 05:08 AM
Johnnny Rock is on a distinguished road.
Send a message via AIM to Johnnny Rock Johnnny Rock's Photo Albums
Default Re: Sequoia rear window not working
Originally Posted by cduncanf
I have a 2001 Sequoia and the rear (tailgate) power window has ceased working. It does not work with the remote or the dash switch. The owner's manual does not show a switch for the tailgate motor, nor was I able to find anything useful on the Toyota wiring diagrams posted in the technical part of TS. Any suggestions to avoid a costly trip to the dealer?
Thanks
Duncan
There alot of threads about this. I herd it happens alot becuse people don't use the rear window much. I got into the habit of rolling the rear window all the way down and then back up again each time I get gas just to make sure it's used. I also herd that sometimes the hot sun makes the black rubber seal stick to the glass if I where you I would have someone push the button to roll the window down and at the same time try to pull the glass down with your hands to help the motor out a little. You might just have a stuck rear window. Let us know how you make out.....Johnnny
2004 Ford Lightning (Sonic Blue)
2003 Cobra with LOTS of work : ) (BLACK)
1996 Cobra (White)
1999 Tacoma 4 wheel drive (Purple in Color)
2002 Tundra Limited (Dark Green or Jade In Color)
2002 Chevy Corvette Z06 (Candy Apple Red)
2003 HighLander Limited (Silver In Color)
2005 Sequoia Limited (Phantom Grey)
