Originally Posted by pcosens
The 1NZFE gas engine in the Cdn/US 2nd Generation Yaris, the Cdn Echo Hatchback (1st gen Yaris) as well as the Scion Xa and Xb uses a proprietary Toyota block heater that slips into a machined hole on the firewall side of the engine block (in the water jacket). Knowing Toyota they will have leveraged this same technology for the Diesel engine as well. Go to your Toyota dealer for their input.
Hope this helps you out . . .
By the way the block heater is extremely effective, makes a huge difference in the cold (05 Echo HB, gas, cold Canadian winters).
Paul
Thanks for the GREAT INFO.
I did some research and here's the part number for the block heater for the ECHO/XA/XB/Yaris 1NZFE gasoline engine.
00213-00885 its about $35 (US) +shipping
25 yrs with TOYOTA
