ther things you might need to know:
Parts Sources Used in this swap
Imported Parts Warehouse 9321-A SewardRd. Fairfield Ohio, 513-874-9881,
Mac@macsparts.com
Brembo Rotors IPW part #0832821
PBR Ceramic pads IPW part #105.09760
Semi-Loader Calipers RH IPW part #141.44231 LH IPW part #141.44232
Local Toyota Dealer
Brake Line Toyota part #473150C020
Brake Line Toyota part #473180C020
Bolts 4 needed Toyota part #9008010298
Shim Kits Toyota part #0494535080
On this list, what is the difference from fully loaded to Semi-loader Calipers? Do you need the Brake lines from Toyota?
What was the total cost for the parts above?
I plan to have my local mech to the TSB. Im going to order all the parts needed however.
thanks for the post...
